Godsdemon
Dec 27, 2020Aspirant
Need help - had to use the reset button in the back
I had to use the reset button in the back last nite. Since I have done this 2 things have happened. I notice that my internet gaming seems to cycle in waves on any mmo experience that I can have ever...
Godsdemon
Dec 28, 2020Aspirant
michaelkenward wrote:
Godsdemon03 wrote:
I have tried the self update and it wouldn't update. It might be worth looking into on your end to fix.
I was referring to the router actually auto updating (thus your end to make sure it does it if you work for netgear) instead of manually doing it with the risk of making it a toaster or a very expensive paper weight.
When I read it I felt it made sense but from your perspective I wasn't descriptive enough.Your end? I have no idea what that means.
I always update manually:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
I do it using an Ethernet connection from my PC. That is safer than relying an an automated process that might crash mid update, especially on a wifi connection.
I have already provided you with a link to the Armor section.
I tried Armor once in a beta test, but don't feel the need to pay for anything like that, so I have no idea how it works for paying customers.
Godsdemon03
Jan 04, 2021Tutor
I did a tracert today- here is what I found:
Does this prove that the modem isn't flaking out and that its my ISP ?
