StElmoQn
Feb 02, 2017Aspirant
Need Help after Factory Reset on NIghthawk Router
Had to physically relocate my desk and computer components yesterday and now for some reason my wired ethernet connection is shot. I can still log on wirelessly and my ISP walked me through many ste...
- Feb 09, 2017
StElmoQn wrote:
I prefer to run the modem as a bridge and use my Nighthawk as the true router. That being said, what exactly will be the setup?
... and then the NIghthawk and the CenturyLink modem are connected from LAN port to LAN port.
Connecting the modem to a Nighthawk LAN port only works if the modem is routing. A LAN port from the CenturyLink modem needs to be connected to the Nighthawk's Internet port.
Note that you can connect it up this way and get it working even if the modem isn't in bridge mode. Some advanced functions (particularly port forwarding) become more difficult. But you should be able to get internet connections up and running. If routerlogin.net fails to connect, try switching over to 192.168.1.1.
Then you can switch the modem to bridge mode as a second step.
Note that if the modem is also providing cable TV services there might be some loss of services when switching to bridge mode. I don't think that will be an issue with CenturyLink, but you might want to confirm that. My own ISP (Verizon FIos) uses their router to provide the program guide, video on demand, and some DVR services. So I use my Netgear router behind theirs (double-routing). So it is possible to leave the modem in router mode if that is necessary.
StElmoQn
Yes I held the button in for at least 10 secobds when I reset the R7000 Nighthawk because I lost my network name and defaulted to a NetgearXX name. The IP address that was manually configured was an Iv4 specifically for the router. We did something with winsock last night as well.
Feb 02, 2017Guru - Experienced User
And the IP address error message is coming from the PC? Or is it on the router web ui?
