StElmoQn
Feb 02, 2017Aspirant
Need Help after Factory Reset on NIghthawk Router
Had to physically relocate my desk and computer components yesterday and now for some reason my wired ethernet connection is shot. I can still log on wirelessly and my ISP walked me through many ste...
- Feb 09, 2017
StElmoQn wrote:
I prefer to run the modem as a bridge and use my Nighthawk as the true router. That being said, what exactly will be the setup?
... and then the NIghthawk and the CenturyLink modem are connected from LAN port to LAN port.
Connecting the modem to a Nighthawk LAN port only works if the modem is routing. A LAN port from the CenturyLink modem needs to be connected to the Nighthawk's Internet port.
Note that you can connect it up this way and get it working even if the modem isn't in bridge mode. Some advanced functions (particularly port forwarding) become more difficult. But you should be able to get internet connections up and running. If routerlogin.net fails to connect, try switching over to 192.168.1.1.
Then you can switch the modem to bridge mode as a second step.
Note that if the modem is also providing cable TV services there might be some loss of services when switching to bridge mode. I don't think that will be an issue with CenturyLink, but you might want to confirm that. My own ISP (Verizon FIos) uses their router to provide the program guide, video on demand, and some DVR services. So I use my Netgear router behind theirs (double-routing). So it is possible to leave the modem in router mode if that is necessary.
StElmoQn
Feb 06, 2017Aspirant
I will have to unhook everything again and put the R7000 straight to my laptop. Still can't get to homepage any other way.
Will let you know what I find.
- StephenBFeb 07, 2017Guru - Experienced User
Will let you know what I find.You can also connect the modem directly to your laptop, and look at the IP address of the laptop. That will give the same information. I am checking to see if the gateway is in bridge mode or not.
If the gateway is also routing (not in bridge mode), you might be better off putting the R7000 in AP mode. That might not fix your home page though.
- StElmoQnFeb 07, 2017Aspirant
Thanks. How exactly do I check the IP of the laptop once I have just the modem connected?
Interesting. I just noticed that the network symbol in the tray just switched to wired ethernet when the modem was directly connected but is showing up as an unidentifiedi network.
