StElmoQn
Feb 02, 2017Aspirant
Need Help after Factory Reset on NIghthawk Router
Had to physically relocate my desk and computer components yesterday and now for some reason my wired ethernet connection is shot. I can still log on wirelessly and my ISP walked me through many ste...
- Feb 09, 2017
StElmoQn wrote:
I prefer to run the modem as a bridge and use my Nighthawk as the true router. That being said, what exactly will be the setup?
... and then the NIghthawk and the CenturyLink modem are connected from LAN port to LAN port.
Connecting the modem to a Nighthawk LAN port only works if the modem is routing. A LAN port from the CenturyLink modem needs to be connected to the Nighthawk's Internet port.
Note that you can connect it up this way and get it working even if the modem isn't in bridge mode. Some advanced functions (particularly port forwarding) become more difficult. But you should be able to get internet connections up and running. If routerlogin.net fails to connect, try switching over to 192.168.1.1.
Then you can switch the modem to bridge mode as a second step.
Note that if the modem is also providing cable TV services there might be some loss of services when switching to bridge mode. I don't think that will be an issue with CenturyLink, but you might want to confirm that. My own ISP (Verizon FIos) uses their router to provide the program guide, video on demand, and some DVR services. So I use my Netgear router behind theirs (double-routing). So it is possible to leave the modem in router mode if that is necessary.
Feb 07, 2017Guru - Experienced User
StElmoQn wrote:
I will have to unhook everything again and put the R7000 straight to my laptop. Still can't get to homepage any other way.
Will let you know what I find.
You can also connect the modem directly to your laptop, and look at the IP address of the laptop. That will give the same information. I am checking to see if the gateway is in bridge mode or not.
If the gateway is also routing (not in bridge mode), you might be better off putting the R7000 in AP mode. That might not fix your home page though.
StElmoQn
Feb 07, 2017Aspirant
Thanks. How exactly do I check the IP of the laptop once I have just the modem connected?
- StElmoQnFeb 07, 2017Aspirant
Interesting. I just noticed that the network symbol in the tray just switched to wired ethernet when the modem was directly connected but is showing up as an unidentifiedi network.
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.C:\WINDOWS\system32>Ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:Connection-specific DNS Suffix . : Home
Link-local IPv6 Address . . . . . : fe80::156c:38ad:6cab:15af%20
IPv4 Address. . . . . . . . . . . : 192.168.0.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1Ethernet adapter Ethernet 2:
Link-local IPv6 Address . . . . . : fe80::982d:b561:a2a8:f97%7
Autoconfiguration IPv4 Address. . : 169.254.15.151
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :Wireless LAN adapter Local Area Connection* 3:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :Tunnel adapter isatap.{30994F15-2BAA-4491-8498-141EA730F32B}:
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.2%11
Default Gateway . . . . . . . . . :Wireless LAN adapter Wi-Fi:
Link-local IPv6 Address . . . . . : fe80::d0b5:3ee:7ea4:8e96%4
IPv4 Address. . . . . . . . . . . : 192.168.1.2
Default Gateway . . . . . . . . . : 192.168.1.1Tunnel adapter isatap.Home:
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.0.2%5
Default Gateway . . . . . . . . . :Ethernet adapter Bluetooth Network Connection:
Connection-specific DNS Suffix . :Tunnel adapter Local Area Connection* 2:
Connection-specific DNS Suffix . :Tunnel adapter isatap.{6EE0CFEB-B814-43EF-B7A9-C3BBA04C9BB2}:
Connection-specific DNS Suffix . :C:\WINDOWS\system32>
- LeeHFeb 07, 2017Prodigy
It looks like your wired connection is to the modem running in router mode 192.168.0.2. And your wireless connection is to your Netgear router 192.168.1.2.
You need to tell your ISP to configure you modem in bridge mode. And then make sure all your wired connections are connected to your Netgear router. You must run one cable from your modem to the yellow WAN port of your Netgear router.
After the ISP configures the modem as a bridge you must also follow a certain sequence to turn on everything. First turn on the modem and give it a couple of minutes for it to finish booting up. Then turn on the router and give it time to boot up. After that you can turn on your computers and other devices.
