crrr4
Feb 03, 2023Aspirant
Need help changing/moving my account/email address over to a newer one
Hello, I created my netgear account years ago using an old email address and would like to move my account over to the new email address/account if possible. I have looked through several forums ...
Feb 03, 2023Guru - Experienced User
I believe you can change the email address by logging into the NG profile account and making changes there:
https://accounts.netgear.com/account
Or you'll need to contact NG support for account management help.
https://www.netgear.com/home/wifi/mesh/orbi/
https://my.netgear.com/support/contact.aspx
crrr4
Unfortunately I don't see anywhere to update/change my email address going to https://accounts.netgear.com/. And I cant create a support ticket cause the support included with my router is expired.
- FURRYe38Feb 03, 2023Guru - Experienced User
You'll need to contact NG support and have them help you then. Nothing we can do here in the forums.
Can send a forum moderator a message and see if they can help you out.
- crrr4Feb 06, 2023Aspirant
I finally see the option now, not sure why it wasnt showing up previously, but now I have to delete the second account I created previously so I can change the email address. Is there a way to do this I dont see an option to delete your account?
- michaelkenwardFeb 07, 2023Guru - Experienced User
