crrr4
Feb 03, 2023Aspirant
Need help changing/moving my account/email address over to a newer one
Hello, I created my netgear account years ago using an old email address and would like to move my account over to the new email address/account if possible. I have looked through several forums ...
crrr4
Unfortunately I don't see anywhere to update/change my email address going to https://accounts.netgear.com/. And I cant create a support ticket cause the support included with my router is expired.
Feb 03, 2023Guru - Experienced User
You'll need to contact NG support and have them help you then. Nothing we can do here in the forums.
Can send a forum moderator a message and see if they can help you out.
- crrr4Feb 06, 2023Aspirant
I finally see the option now, not sure why it wasnt showing up previously, but now I have to delete the second account I created previously so I can change the email address. Is there a way to do this I dont see an option to delete your account?
- michaelkenwardFeb 07, 2023Guru - Experienced User
- crrr4Feb 07, 2023Aspirant
I was able to log into the nighthawk/netgear app on my phone under the account/email address I want to delete and there is an option to delete account. I did that but I am still unable to change my email address it says email address already in use. However I just realized that didnt delete the account, how do I close this account so I can modify my old account with the new ones email address?
