Reflex101
Dec 07, 2021Guide
(Need help) debrick unresponsive R6900v2
I need help debricking a r6900v2 because of a failed software update
- Dec 11, 2021
I give up I'm buying a link router from your competitors and using ddwrt.
Dec 07, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Reflex101
Dec 09, 2021Guide
tftp: can't read from local file 'R9000v2-V1.2.0.88.img'
- plemansDec 09, 2021Guru - Experienced User
did you follow the instructions precisely?
And make sure the file was extracted to the proper location?
If its not reading it, either its not extracted, not in the proper location, or your path/file name isn't correct.
- Reflex101Dec 09, 2021Guide
Yes, I followed the instructions percisely!
Yes, It was extracted using 7-zip and the file placed on the desktop, I changed the directory to one drive on win 10.
If my pathway file name was not correct then how do I fix it?
- plemansDec 10, 2021Guru - Experienced User
Tough to know how to fix it when we can't see what you're typing into the command line or where the file is located. The command line requires you type it exact to the location and the file name. Thats why the video can help at times.
Have you tried using an earlier firmware?
