Reflex101
Dec 07, 2021Guide
(Need help) debrick unresponsive R6900v2
I need help debricking a r6900v2 because of a failed software update
- Dec 11, 2021
I give up I'm buying a link router from your competitors and using ddwrt.
Reflex101
Dec 09, 2021Guide
tftp: can't read from local file 'R9000v2-V1.2.0.88.img'
Dec 09, 2021Guru - Experienced User
did you follow the instructions precisely?
And make sure the file was extracted to the proper location?
If its not reading it, either its not extracted, not in the proper location, or your path/file name isn't correct.
- Reflex101Dec 09, 2021Guide
Yes, I followed the instructions percisely!
Yes, It was extracted using 7-zip and the file placed on the desktop, I changed the directory to one drive on win 10.
If my pathway file name was not correct then how do I fix it?
- plemansDec 10, 2021Guru - Experienced User
Tough to know how to fix it when we can't see what you're typing into the command line or where the file is located. The command line requires you type it exact to the location and the file name. Thats why the video can help at times.
Have you tried using an earlier firmware?
- michaelkenwardDec 10, 2021Guru - Experienced User
Did you get any responses to the commands you entered?
They can point to possible problems.
This process depends on timing and can take several attempts.
Don't give up. Keep trying and pay attention to the responses you get.
- Reflex101Dec 10, 2021Guide
Here's my screenshot of my cmd on win 10.
