Reflex101
Dec 07, 2021Guide
(Need help) debrick unresponsive R6900v2
I need help debricking a r6900v2 because of a failed software update
- Dec 11, 2021
I give up I'm buying a link router from your competitors and using ddwrt.
Reflex101
Dec 11, 2021Guide
Do I use command prompt to use nmrpflsh? What do I type in?
Reflex101
Dec 11, 2021Guide
- michaelkenwardDec 12, 2021Guru - Experienced User
Reflex101 wrote:
....I'm buying a link router from your competitors
We do not have "competitors". You seem to be under the impression that the people who answered your questions work for Netgear. They don't. This community is essentially a user-to-user venue with some input from a small band of Netgear techies.
Reflex101 wrote:
...using ddwrt.
That might not be a good idea. Alternative firmware suppliers often require you to use something like TFTP, which does not seem to be something that comes easy to you.
