TheJ-Man
Nov 09, 2022Follower
Need Help! Nighthawk AC1900 Router (R6900P) reboots when I leave with cellphone
So my Nighthawk AC1900 Smart WiFi Router (R6900P) will disconnect from the internet/reboot whenever I leave the house or disconnect my phone from the wifi. My cellphone does contain the nighthawk app....
Nov 09, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
