Retired_Member
Jun 28, 2021Need help pls
i just got my xr300 today and i have no idea about bridge mode. I don't know how it work can i use xr300 with my family xfinity modem/router combo without putting in bridge mode for gaming ps5....
Jun 28, 2021Guru - Experienced User
what actual gatewa is it from xfinity?
did you try putting the netgear IP address into the xfinity's dmz?
or putting the netgear into access point mode
- Retired_MemberJun 28, 2021
Xfiniity TG1682G'
- plemansJun 28, 2021Guru - Experienced Userdid you try putting the netgear IP address into the xfinity's dmz?
or putting the netgear into access point mode- Retired_MemberJun 28, 2021
I can't access dmz on xfinity
If i put xr300 on ap mode. Can I use all the features that the router have . Like gaming features.
