Piejack
Nov 17, 2021Aspirant
Need help Port-Forwarding on a Netgear RAX35
I need to port-forward port 44158.
When I try doing this, I get the message, "The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type"
The port I need is for IP address 192.168.1.28
I want to open port 44158.
How can I do this, please?
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Please give ISP modem brand and model# information there along with uPnP status, enabled or disabled.
Thank you.
