Pat_MO
Aug 04, 2021Follower
Need Help set up Nighthawk AC2300, Model R7000P
I did not use Nighthawk Router AC2300 for more than 6 mo (because I used 5G Gateway). I just start Spectrum home internet. I connect AC2300 to the Spectrum modem, I download the nighthawk app. I can ...
michaelkenward
Aug 05, 2021Guru - Experienced User
Pat_MO wrote:
I just start Spectrum home internet. I connect AC2300 to the Spectrum modem, ...
Your devuce is the R7000P? (AC2300 is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.)
It might help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
If you are using this router with a new modem, then it can help to factory reset the router so that it forgets any settings inherited from a previous modem.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
