MattyCakes
Jul 30, 2019Aspirant
Need help setting up time machine
Hello netgear community. I am having a hard time setting up a time machine backup to a usb 3.0 drive (no external power) connected to my nighthawk wifi router. I have been through countless tutoria...
- Jul 30, 2019
Hello Matt
You will need to roll back the firmware as the latest firmware has removed this feature.
DarrenM
DarrenM
Jul 30, 2019Sr. NETGEAR Moderator
Hello Matt
DarrenM
- MattyCakesJul 30, 2019Aspirant
Yes, this did work. Makes me wonder why netgear would drop this feature. The other worry is that if some critical security updates happen, I am going to have to upgrade and lose time machine.
- Tom54Aug 11, 2019Aspirant
I was also caught offguard with the loss of Time Machine capability when updating firmware. Can you point me to how to roll back to the previous version? Thank you.
- myerswAug 11, 2019Master
Ah yes. You need to run out of date firmware with maybe security issues, just to have time machine.
What garbage is this anyway, Netgear?
DarrenM wrote:Hello Matt
DarrenM
Is anyone minding the inmates any more? Downgrade to retain features is not a good answer. Maybe Netgear needs to think about two tracks. One the traditional folks just wanting updates and the other track for the Armor folks?
