cks2022
Mar 24, 2023Follower
Need Help to check and unblock port 25
Hi, I have an issue in sending email from my web application from my home network. I get - access denied error. I use smtp client and use smtp host and port as 25. This works fine as long as I a...
Mar 25, 2023Guru - Experienced User
Might help to know what your actual setup is?
what router do you have?
what firmware is on it?
what modem/gateway is it connected to?
