msbutton
Sep 14, 2021Aspirant
Need help to determine what to buy
Sorry this is kind of broad but I am looking for some help in designing what my purchase(s) should be. I have a 3 story home, my ISP router is a Bell (Canada) Home Hub 3000 with 1.5 gig download and...
Sep 14, 2021Guru - Experienced User
For that kind of ISP service, to take full advantage of that, you'd want something that has a 2.5Gb speed rated WAN port and AX wifi. Unfortuneately there isn't alot of router with 2.5Gb rated LAN ports as of yet. Orbi RBK8 series and RAX200 and RAXE500 has 2.5Gb Rated WAN ports.
- msbuttonSep 14, 2021Aspirant
Yeah I understand I can't get the full 1.5 gig. I just want something that is not going to die on reception when I walk to Bedroom 2, or out through the back door.
My ISP is well over what I need, i get that even as my own PC ethernet is maxed at 1gig. So for pretend lets say my ISP is 1gig.
Should i buy a netgear router and than mesh network, or do I just need to buy the latter? I was thinking the router then the mesh, using the three pods as satalites, potentially 2 upstairs and 1 in basement. Or do you know if you have to use 1 as a router, therefore negating the need for buying a seperate router as well.
Here is my house Layout, all the TV's are smart TV's. 1 PC is wifi, other is Ethnet. Here is the typical things in the house
3 x ipads
3 x iphones
1 x samsung
2 x alexa
security system on its own router
1 x wifi printer
4 x smart tvs
1 x roku recevier
1 x firestick
2 x xboxs
1 x PC on wifi
In the current configuration, my son right about the office and my daugther in the bedroom 2 can barely get a signal. If i walk out the back porch I do not receive a signal, even right outside. Master Bathroom has no signal
- michaelkenwardSep 15, 2021Guru - Experienced User
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
