it_geek
Feb 01, 2020Guide
Need Help Understanding what the Blinking LEDs mean in the bootloop (NETGEAR X6 R8000)
So, pursuant to this thread, I took a footage of the blinking LEDs on both of my NETGEAR routers. Details of both routers, including their respective firmware versions are available in the thread...
- Jun 06, 2020
So the USB-Serial cable arrived in my mailbox yesterday.
Got into the router via a terminal window (Mobaxterm), reflashed the firmware to a lower level (v1.04.28) and did an nvram erase. Seems there's a bug in the latest version (v 1.04.46) that causes the nvram to fill and not be able to clear it on its own.
Got both routers working in a normal state, although one of the routers keeps dumping
Magic bitmask 0x1985 (and other addresses) not found at 0x043a0010 (and other addresses): 0x4c18 (and other addresses) instead error, which lengthens the boot time.
Wireless performance has also dropped significantly but it's better than leaving it as a brick, i guess.
it_geek
Feb 18, 2020Guide
Bumping up this thread to see if anyone else has experienced a similar problem (with this pattern of lighting) and can provide an explanation as to why the router keeps rebooting like this.
it_geek
Apr 17, 2020Guide
Issue still remains unresolved. Continuing to look for answers on this forum.
My shipment on the Serial cable for this router has been stuck since end of February due to delays caused by COVID-19, would appreciate if anyone here has alternative solutions in the meantime.
- it_geekJun 06, 2020Guide
