LHoward6037
Nov 12, 2020Aspirant
Need help with getting the right wifi extender to go with my IInet modem
Hi I have a iinet modem in our loungeroom and im wanting to work from home in the back of our long narrow house which is a dead spot so im needing a wifi extender My work laptop does not have...
LHoward6037
Thanks for your comment. I dont have a router! Do i need to get one? The home is a long, single level, narrow 3 bed, by 2 bath home. The room i want to work in is approx 20 square metres away from where the modem is (ie: at the back of house and the modem is at front of house).
i just converted m2 (square metres) into feet which is 215.278
LHoward6037
Forgot to say.... Intertior walls are double brick
- plemansNov 12, 2020Guru - Experienced User
That brick is probably your issue. Brick is one of the top blocking materials of wifi.
any chance of using an ethernet run, power line adapters, or moca (ethernet over coax) adapters?
