kleaverjr
Aug 23, 2022Follower
Need Help With Netgear Ready Share and Windows 11 NOT connecting
HELP! I am at my wit's end with a problem with a friends computer. Somehow I did manage before to connect Windows 11 with the Netgear ReadyShare USB connected printer, and tested it and tested it a...
michaelkenward
Aug 24, 2022Guru - Experienced User
It might help if you said what Netgear router you are using. They aren't all the same.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist. That will probably include any printer utilities you need.
kleaverjr wrote:
So what am I missing. Can someone PLEASE give me a step by step instruction on how to MANUALLY install a Printer that is connected to a Netgear Router via USB (and Netgear ReadyShare says it's connected and ready to go) with Windows 11.
That is in most of the manuals I have seen.
I don't understand why Windows 11 cannot discover this printer, when Netgear ReadyShare says it's connected and ready.
Could it be that the friend who helpfully removed the printer did it in Windows? If so, this could be the wrong place to seek help.
