Deenkee-Du
Nov 12, 2021Aspirant
Need information not present in the Nighthawk 7450 log to report network abuse.
Hello! Reports of abuse to most network service/telecommunications service providers requires specific types of information to be incuded in the report before any action is taken to mitigate/prevent...
schumaku
Nov 12, 2021Guru - Experienced User
Dear Thomas,
Serisously wondering on how you detect and see network abuse to report if you don't have the information available you're asking for here. Hope you don't build on the misleadinging or often false warnings from these consumer routers.
-Kurt
Deenkee-Du
Kurt,
Have you looked at the logs? Here are a few revealing entries from mine.......
***BEGIN LOG EXCERPT^^^
[DoS attack: ACK Scan] from source: 151.101.26.252:443 Saturday, November 06,2021 21:40:44
[DoS attack: ACK Scan] from source: 72.21.81.237:443 Saturday, November 06,2021 21:40:12
[DoS attack: ACK Scan] from source: 54.187.87.190:443 Saturday, November 06,2021 21:38:00
[DoS attack: ACK Scan] from source: 52.40.172.46:443 Saturday, November 06,2021 21:37:35
[DoS attack: ACK Scan] from source: 151.101.130.132:443 Saturday, November 06,2021 21:37:07
[DoS attack: ACK Scan] from source: 23.37.224.57:443 Saturday, November 06,2021 21:36:44
[DoS attack: ACK Scan] from source: 3.224.57.93:443 Saturday, November 06,2021 21:36:22
[DoS attack: ACK Scan] from source: 151.101.26.252:443 Saturday, November 06,2021 21:34:13
[DoS attack: ACK Scan] from source: 151.101.26.252:443 Saturday, November 06,2021 21:33:46
[DoS attack: ACK Scan] from source: 34.217.225.30:443 Saturday, November 06,2021 21:32:22
[DoS attack: ACK Scan] from source: 34.212.111.15:443 Saturday, November 06,2021 21:30:55
[DoS attack: ACK Scan] from source: 72.21.81.237:443 Saturday, November 06,2021 21:28:54
[DoS attack: ACK Scan] from source: 44.236.75.167:443 Saturday, November 06,2021 21:28:00
***END LOG EXCERPT^^^
So, the "abuse" (a DDOS attack) is identified in the log and the attack has gotten bad enough that it has made a noticeable impact on my WAN network performance.In addition, (and this is just a hunch), the amount of heat generated by the router would indicate that its 4 processors are really struggling to keep up with all the requests. Historically, my LAN (we've got just a few devices accessing the Internet) does not generate enough of a workload to cause a router to get hot. Hope that answers your question.
Thomas H.
- FURRYe38Nov 12, 2021Guru - Experienced User
Do a whois lookup on those IP addresses from in from the WAN side.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Have your ISP help you reboot the ISP modem and get a new WAN IP address...
