Deenkee-Du
Nov 12, 2021Aspirant
Need information not present in the Nighthawk 7450 log to report network abuse.
Hello! Reports of abuse to most network service/telecommunications service providers requires specific types of information to be incuded in the report before any action is taken to mitigate/prevent...
Deenkee-Du
Kurt,
Have you looked at the logs? Here are a few revealing entries from mine.......
***BEGIN LOG EXCERPT^^^
[DoS attack: ACK Scan] from source: 151.101.26.252:443 Saturday, November 06,2021 21:40:44
[DoS attack: ACK Scan] from source: 72.21.81.237:443 Saturday, November 06,2021 21:40:12
[DoS attack: ACK Scan] from source: 54.187.87.190:443 Saturday, November 06,2021 21:38:00
[DoS attack: ACK Scan] from source: 52.40.172.46:443 Saturday, November 06,2021 21:37:35
[DoS attack: ACK Scan] from source: 151.101.130.132:443 Saturday, November 06,2021 21:37:07
[DoS attack: ACK Scan] from source: 23.37.224.57:443 Saturday, November 06,2021 21:36:44
[DoS attack: ACK Scan] from source: 3.224.57.93:443 Saturday, November 06,2021 21:36:22
[DoS attack: ACK Scan] from source: 151.101.26.252:443 Saturday, November 06,2021 21:34:13
[DoS attack: ACK Scan] from source: 151.101.26.252:443 Saturday, November 06,2021 21:33:46
[DoS attack: ACK Scan] from source: 34.217.225.30:443 Saturday, November 06,2021 21:32:22
[DoS attack: ACK Scan] from source: 34.212.111.15:443 Saturday, November 06,2021 21:30:55
[DoS attack: ACK Scan] from source: 72.21.81.237:443 Saturday, November 06,2021 21:28:54
[DoS attack: ACK Scan] from source: 44.236.75.167:443 Saturday, November 06,2021 21:28:00
***END LOG EXCERPT^^^
So, the "abuse" (a DDOS attack) is identified in the log and the attack has gotten bad enough that it has made a noticeable impact on my WAN network performance.In addition, (and this is just a hunch), the amount of heat generated by the router would indicate that its 4 processors are really struggling to keep up with all the requests. Historically, my LAN (we've got just a few devices accessing the Internet) does not generate enough of a workload to cause a router to get hot. Hope that answers your question.
Thomas H.
Nov 12, 2021Guru - Experienced User
Do a whois lookup on those IP addresses from in from the WAN side.
Have your ISP help you reboot the ISP modem and get a new WAN IP address...
