Doogal1948's avatar
Doogal1948
Follower
Jun 21, 2021
Need longer USB cable
Is it possible to get a longer USB cable for this adaptor ?
WNDA3100v2
  • schumaku's avatar
    schumaku
    Buy some indusry standard USB A (USB 2.0 or better) extension cable (male - female).
  • plemans's avatar
    You can always buy after market usb cable extenders. Past a certain distance though you'd need to move from passive cables to active powered cables or even usb---ethernet adapters. So it depends on how far of distance you're talking.
    https://blog.tripplite.com/usb-cable-max-length
