poulet750
Nov 06, 2021Aspirant
need more mbps
Hi, i want to know why at my router across my modem i can read 100mbps and at my second router in an other room at the second floor i have only 20mbps. At my second floor i cant do what i want cuse m...
Nov 07, 2021Guru - Experienced User
You didn't give us much to go off.
1. what modem/gateway do you have?
2. what router do you have?
3. what firmware is on it?
4. whats your 2nd router that you're connecting to? Is it hardwired in? wireless?
5. How are you testing speeds? wired? wireless? 2.4ghz? 5ghz?
6. how big is your home? what are the interior walls made of? How far from router 1 is the 2nd device?
these are all key as we need to know full details of your setup and how you're testing.
poulet750
Nov 07, 2021Aspirant
My version is MR60. firmware version v1.0.6.116. my second router is wireless. test=wireless with 5ghz. the distance from the two router is about 75feet at the maximum. the wall is in plastered cement.
- michaelkenwardNov 07, 2021Guru - Experienced User
Where did that suddenly come from? What was that XRM570 all about?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
So you have two routers using the same Internet connection?
It gets messier and messier.
What is this unnamed "second router"? How is it set up? Wifi repeater? Router?
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR SupportWe still don't know hat modem/gateway you have.
Bit of a stretch for wifi, especially 5 GHz and the material is likely to soak up the wifi signal. Depending on the quality of the internal mains circuit, it might be worth investigating Powerline Ethernet.
