Abuelo13x's avatar
Abuelo13x
Follower
Apr 29, 2022
Need power adapter for nighthawk X6S router Model R7960P. Please
If you have this router, please provide the model number for the power supply so I can get the right voltage, amperage and connector to the router. Mine came without a power supply.   Thanks, Abue...
  • wcalifas's avatar
    Apr 30, 2022
    Its on the label under the router. I looked at thst model on Google pictures and on the label it says 19v 3.16A(amperage)
