joerozic
Dec 19, 2021Follower
need power cord
Dec 20, 2021Guru - Experienced User
Netgear doesn't sell replacement power supplies/cords. But most of netgears devices use pretty generic power supplies that you can pickup from 3rd parties like amazon for pretty reasonable. You can even check in your parts bin/old device bin and see if it has a matching power supply. Just make sure it has the same voltage and polarity. It can have more amperage but don't go with something that has less or it won't run or if it does, won't be stable.
- wcalifasDec 20, 2021Prodigy
you can find some on ebay or amazon, just make sure its the same voltage and polarity.
- michaelkenwardDec 20, 2021Guru - Experienced User
and enough amps
More is fine. Less can cause problems.
