Mordred478
Jun 30, 2017Follower
Need replacement AC5300/R8500 power adapter...where do I get an authorized one?
I need a real, Netgear replacement for the power adapter for my AC5300/R8500 and can't find one anywhere. The only thing I found was fake, Chinese knock-offs on eBay, which I will not buy. Does ...
- Jul 06, 2017
Hi Mordred478,
You can use any power adapter for as long as you follow the specification of the router's power. Check the post below.
JamesGL
Jul 06, 2017NETGEAR Employee Retired
Hi Mordred478,
JamesGL
Jul 09, 2017NETGEAR Employee Retired
Hi Mordred478,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
