MarcioAB2
Apr 30, 2023Aspirant
Need restore SMB1 or SMB v1 support for ReadyShare Storage.
I use a small USB external HD in the ReadShare Storage as a music library for SONOS S1 controller. This has worked fine for years but for months now it is not working anymore. The SONOS support inf...
michaelkenward
Apr 30, 2023Guru - Experienced User
MarcioAB2 wrote:
I can not find in the Nighthawk R7000 configurations where to re-enable SMB v1 support or what should be the firmware I need to use.
It is a "feature" in Windows.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
