MarcioAB2
Apr 30, 2023Aspirant
Need restore SMB1 or SMB v1 support for ReadyShare Storage.
I use a small USB external HD in the ReadShare Storage as a music library for SONOS S1 controller. This has worked fine for years but for months now it is not working anymore. The SONOS support inf...
schumaku
Apr 30, 2023Guru - Experienced User
Small external USB disk: Yes.
Readyshare: Nope.
The Netgear routers like the R7000 never had a simple user accessible smb mounter so you could re-share the Sonos S1 hosted storage.
MarcioAB2 wrote:
The SONOS support inform I need SMB v1 to use SONOS S1 controller and probably some router firmware upgrade should removed or disabled it.
Yet another embedded system which is limited to smb1 support - to make it even slower it's like most Android user space smb1 processing.
it was never configured in a way you like to remember it ....
