MarcioAB2
Apr 30, 2023Aspirant
Need restore SMB1 or SMB v1 support for ReadyShare Storage.
I use a small USB external HD in the ReadShare Storage as a music library for SONOS S1 controller. This has worked fine for years but for months now it is not working anymore. The SONOS support inf...
schumaku
Apr 30, 2023Guru - Experienced User
FURRYe38 wrote:
I don't think it was FW, maybe was Windows update? I know MS disabled SMBv1 with in Windows. It can be re-enabled I think for Windows.
Almost correct. Microsoft introduced a SMB 1.0/CIFS Automatic Removal service which kicked in if there are no SMB 1.0/CIFS client connections active for a certain time. Check the Windows Features - Turn Windows features on off controls ... it's all there. Yes, it came in with some Windows Upgrade feature enhancements a loooong time ago.
MarcioAB2
Allow me to show what I have:
(1) The ReadySHARE USB Storage page.
(2) The Windows resources with SMB v1 disabled
(3) The working ReadySHARE USB Storage local network.
(4) SONOS S1 network share page
(5) SONOS S1 error
R7000 must be working currently with SMB v2 or v3 ( I do not know ). But not v1, for sure.
R7000 was working with v1 in the past ( do not recall when ) and all was OK.
SONOS S1 application depends of v1 and it worked for many years.
Currently it is not working anymore, because R7000 is working with SMB v2 or v3.
I need to move the firmware back to a version that was using v1 but I do now know what.
Does this make sense?
