domelro2
Feb 05, 2025Aspirant
Need some help with router
Any help / advice is greatly appreciated
So recently i got my hands on a nighthawk x10 and I've done everything i can think of to get this dumb thing to work, when it boots up the gigabyte numbers cycle through then all 6 flash solid orange / red for like 2 seconds,
I plug my brand new ethernet cables into the router from my starlink router and connect to my pc, it allows me to go through the set up process but still doesn't connect
Which one? X10 is not a unique Netgear model number. Many devices come with the AC/AX/X tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
Most X19 kit is now pretty old an approaching the "EOS" stage.
I plug my brand new ethernet cables into the router from my starlink router and connect to my pc, it allows me to go through the set up process but still doesn't connectWhat happens when you try to connect? Any messages?
How are you trying to set it up? Nighthawk App? Web browser and the graphical user interface (GUI)?
You have to be careful with adding one router to another router.
Starlink also has special requirements.
Search - NETGEAR Communities – Starlink
Disclaimer: Just another user with time on their hands.
Can you access the R9000s web page at all?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset on the router been performed at all?
- domelro2Aspirant
domelro2 wrote:Any help / advice is greatly appreciated
I plug my brand new ethernet cables into the router from my starlink router and connect to my pc, it allows me to go through the set up process but still doesn't connect. https://routerlogin.uno/
I got this,...
