tomhandley8
Apr 04, 2021Tutor
Need to add mesh to Nighthawk X6 - recommendations?
Hello. I purchased the Nighthawk X6 to optimise the WiFi in my house and also apply controls using the Circle app. My issue is that my son has been used to plugging in an Ethernet cable with the exten...
- Apr 05, 2021
Are you just adding 1 or more than 1?
If its just one, I'd recommend a triband mesh extender like the ex7700/ex8000
If you're needing more than 1, then I'd look at a full mesh system like orbi
MaryESmith
Apr 04, 2021Aspirant
Cant find details on this.. i want to add mesh to my network.. the current router works great in most places.. but looking to add mesh +ethernet to media areas like in my living room where the devices could use a boost of bandwidth for streaming services. I like the nighthawk satelites they provide an ethernet for devices that arent wifi enabled or dont support faster wifi technology.
Can I "mesh" satelite boxes directly with my ac3000 or do i have to use the router?... I know i can just plug the "internet" port into my routers network but that sort of defeats the purpose doesnt it?.. i already have fantastic speed on my second floor... i'm just looking to improve my other floors..
any input much appreciated.
