torontowolf
Jun 16, 2021Aspirant
Need to monitor uptime and downtime
(Disclaimer: Although I can navigate through the Netgear settings, I'm still quite a newb when it comes to networking generally) I've noticed that my work VPN drops during the night. A few nights ...
antinode
Jun 16, 2021Guru
> So....is there a way I can set things up so I can see when/if my
> internet connection drops, and for how long [...]
Built into your router? Unless you count the logs, I know of
nothing.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "View and
Manage Logs of Router Activity".
> [...] is there a Mac s/w I can download that will help me acquire this
> info?
I know of nothing, but I haven't looked. I'd be a little amazed.
It ought not to be very difficult to write a program which checks
network connectivity or router status periodically, and records the
results, or sends an e-mail notfication when an interesting event
occurs.
> [...] I'm still quite a newb when it comes to networking generally
If that means that you've never written a computer program, then you
might not be well prepared to embark on such a project.
I'd expect your Mac to come with some basic network programs, like,
say, "ping" and "wget", with which many basic (or more elaborate) tests
could be built. As a quick example, here's a one-line shell script
which uses "ping" to test basic connectivity to a destination of your
choice. (Around here, "8.8.8.8" succeeds, "8.8.8.9" fails):
$ if ping -c 1 -q 8.8.8.8 > /dev/null ; then echo OK ; else echo BAD ; fi
OK
$ if ping -c 1 -q 8.8.8.9 > /dev/null ; then echo OK ; else echo BAD ; fi
BAD
Launch a Terminal window, type (or copy+paste) the commands, and see
for yourself. (Start at "if", not at the "$" prompt.)
Plenty of more complicated things could be done, of course: more
complex tests and actions. In any case, I'd expect this to be a DIY
task, not something you'd find on a shelf, but, as I said, I haven't
looked.
torontowolf
Jun 18, 2021Aspirant
Thanks for your reply. Yeah, everything I've read talks about monitoring network activity, but in the context of apps and open ports, etc. Virtually nothing (except for large company networks) about monitoring uptime and downtime.
Given your response and the lack of other responses, I'm thinking right about now that I'm out of luck on obtaining something already created (and yeah, I"m not a coder or script kiddie either, which doesn't help.)
- antinodeJun 18, 2021Guru
> [...] I"m not a coder or script kiddie [...]
So far as I know, people aren't born with computer-programming
skills, but many people have managed to acquire some. Having an actual
problem to solve can make it easier to learn, compared with having to
plow through some shell-scripting primer, trying to imagine how any of
it might be useful.
