LSEinLAS
Jul 07, 2017Aspirant
Need to release IP address on R8000, Blacklisted IP from DHCP
Purchased new desktop and dynamic IP address was blacklisted from previous user, The R8000 will not release it, even though I did a hard reset on the router and modem. I plug the modem into the des...
- Jul 08, 2017
Sage,
I spent hours and hours on this problem. Your suggestion fix the problem. On my computer, changing the mac address did not work but changing it to my desktop mac address did. A reboot of the modem and then the router and finally the computer did it. Thanks again. Hope this stays on top of the list. Many others are facing the same thing and some are getting pretty angry. There really should be a release function in the router software.
The first thing I did was check to see if the new number was blacklisted.
TheEther
Jul 07, 2017Guru
Go to the Internet settings on the router and change the MAC address under Router MAC address. You can either change the last couple of digits of the router's current MAC address or you can use your desktop's MAC address. This should trick your ISP into handing you a new IP address.
- LSEinLASJul 08, 2017Aspirant
Sage,
- TheEtherJul 08, 2017Guru
Glad you got it working. You can't blame the router. Blame the ISP. Their DHCP server will cache the IP address it assigned to your router based on its MAC address.
