LSEinLAS's avatar
LSEinLAS
Need to release IP address on R8000, Blacklisted IP from DHCP
Purchased new desktop  and dynamic IP address was blacklisted from previous user, The R8000 will not release it, even though I did a hard  reset on the router and modem. I plug the modem into the des...
  • LSEinLAS's avatar
    LSEinLAS
    Jul 08, 2017
    Sage,
    I spent  hours and hours on this problem.  Your suggestion fix the problem. On my computer, changing the mac address did not work but changing it to my desktop mac address did. A reboot of the modem and then the router and finally the computer did it.  Thanks again. Hope this stays on top of the list. Many others are facing the same thing and  some are getting pretty angry. There really should be a release function in  the router software.
    The first thing I  did was check to see if the new number was blacklisted.
