AlwaysConfused
Sep 11, 2021Tutor
Negear Nighthawk R8000P VPN service timesout after a few hours of usage
Hello everyone,
I am having small issue that I cannot figure out where the issues is coming from. Having turned on my VPN service within the Netgear Advanced settings. It works for a few hours and I can connect to it using my phone using the OpenVPN client app. However, there comes a moment of using that when I try to re-connect that I get a timeout. Please see OpenVPN log below...
13:16:06.150 -- ----- OpenVPN Start -----
13:16:06.151 -- EVENT: CORE_THREAD_ACTIVE
13:16:06.183 -- OpenVPN core 3.git::662eae9a:Release android arm64 64-bit PT_PROXY
13:16:06.183 -- Frame=512/2048/512 mssfix-ctrl=1250
13:16:06.183 -- UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
6 [persist-key]
7 [persist-tun]
13 [verb] [5]
13:16:06.183 -- EVENT: RESOLVE
13:16:06.303 -- Contacting My Router's IP and Port number via UDP
13:16:06.303 -- EVENT: WAIT
13:16:06.309 -- Connecting to My Router's IP and Port number via UDPv4
13:16:16.155 -- Server poll timeout, trying next remote entry...
Looking through my Nighthawk's logs I see no entry. It doesn't even get to that point. I am left scratching my head as to why this is occuring.
The only temporary fix that I do each and everyday (slightly annoying) that I turn off the VPN service and turn it back on and everything works just fine (for only a few hours then back to timeouts).
Can anyone recommend something that I should look into?
Found this within the KB articles here and am thinking maybe it's related?
Thanks in advance!
No RepliesBe the first to reply
