ouadasa
Jan 16, 2024Tutor
Negear R9000 , protocol 802.1Q
Hello , i would like to know if the R9000 has the 802.1Q protocol , if so ,how to active it to use it . Thanks
Jan 16, 2024Guru - Experienced User
Check the user manual for VLAN information and support. Most routers only have VLAN support for ISP services.
For LAN side VLAN, those are mostly kept to the LAN switch domain.
- ouadasaJan 16, 2024Tutor
in fact, i want to connect my R9000 to my ISP's router (witch i convert to a bridge) , a priori i will need 802.1Q .
- FURRYe38Jan 16, 2024Guru - Experienced User
Ask the ISP if any VLAN configuration is needed.
i have already configured an other router with vlan 881 ( witch worked )
- michaelkenwardJan 16, 2024Guru - Experienced User
What is that ISP router and how is it bridged?
I ask because "bridge" means different things in different contexts.
If you do have problems, have you considered using the ISP's router as a router and the R9000 is an access point?
It is a case if weighing up which router best meets your needs.
