kywil0327's avatar
kywil0327
Nest Cameras cannot connect [WLAN access rejected: incorrect security] from MAC address
My nest cameras all lost connection to my network at the same time.  I had recently (a day or 2 before) modified my extender (EAX80) to be an access point on a different SSID.  I didn't touch any other setting.
Afterwards, many of my Nest products no longer connect.  Cameras give NC007 errors.  On my router logs I see:  [WLAN access rejected: incorrect security] from MAC address <Camera Mac Address>.
I do not have filtering enabled though.  The cameras do work on different networks.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Are you using WPA2 security on the router? Have you tried to resync the cameras?
      DarrenM
