BruceBrouwer
Jun 04, 2017Aspirant
Netflix blocked on Nvidia Shield TV with Live Parental Controls enabled
I am unable to play Netflix videos on my Nvidia Shield TV when Live Parental Controls are enabled. If I use OpenDNS filtering with similar settings and manually specifying the OpenDNS DNS server...
- Jun 17, 2017
The solution was to switch the router firmware to DD-WRT and follow these instructions:
https://www.dd-wrt.com/wiki/index.php/OpenDNS
The stock firmware provides no useful information in troubleshooting the problem.
ElaineM
Jun 06, 2017NETGEAR Employee Retired
How about if you set Netflix under Whitelist to Never block?
You may set it in this link. Once you're logged in, go to Account Settings and select Blacklist/Whitelist tab.
BruceBrouwer
Jun 17, 2017Aspirant
- FURRYe38Jun 17, 2017Guru - Experienced User
Good Luck.
