runj
Apr 27, 2022Guide
NetG Router Scam
I'm an idiot and called a number after google searching for orbi set up help. I thought it was fishy and the guy promised me it wasn't a scam and said he would refund me if it was. I said fine and ...
michaelkenward
Apr 28, 2022Guru - Experienced User
runj wrote:
My question is this: did I get lucky with a good soul that truly just refunded me or am I about to have my identity stolen in some way? If the latter, what do you suggest to remedy the situation? New router? Change all passwords?
I would check my credit card statements for any signs of further action. But it is odd if they provided a spontaneous refund.
Then again, some of us have ben trying to persuade Netgear to go after these crooks. Maybe the lawyers have started to throw their weight around.
As to the router, just change the admin password. There isn't much that a hacker can do, but if you did provide them with that password, I'd change it as a precaution. There isn't much they can do with the wifi passwords, unless the scammer happens to be a neighbour.
