Rsmith3752's avatar
Jan 12, 2022
NETGEAR - Nighthawk EAX18 AX1750 Wi-Fi 6 Mesh Range Extender
Can you run 2 NETGEAR - Nighthawk EAX18 AX1750 Wi-Fi 6 Mesh Range Extender off the same network with no degradation? Already have 1 in my wife’s office and it’s fine, just bought a second one for my living room. Both will be Wi-Fi from the router due to no wiring in the house. Please advise. Thank you
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products:
    https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
    Thank you.
  • plemans's avatar
    Can you? yes.
    Should you? debatable and depends on how you're setting it up.
    to prevent degradation in speeds, set them up in a star configuration and not daisy chained.
    Star:  extender<-------router------->extender
    daisy: router----->extender------>extender
    also, if you run into issue with drops/stability problems, set one of the extenders with their own ssid that is seperate from the router/other mesh extender.
    • Rsmith3752's avatar
      Rsmith3752
      Tutor
      Thanks for responding but due to no wiring in my house and location of router there is no way possible to do Star only daisy due to no wiring. I will not be using the extenders at the same time. My wife works during the day off one and I game at night off the other. Just asking to see if 2 would work this way if not before I open the second one I’ll send back. Thanks
      • plemans's avatar
        I wasn't meaning wire them in.
        I was just meaning make sure the extenders are connecting to the router and not connecting from one extender to the extender. that'll drop throughput.
