Nuuch's avatar
Nuuch
Follower
May 26, 2022
Netgear 18
Will this handle 200 mb
  • Which router model? Most current routers don't have issues with 200 Mbps
  • plemans's avatar
    "netgear18" is more than likely  your ssid and not your model.
    So as microchip8 says, what actual model do you have? (look at the label)
  • michaelkenward's avatar
    michaelkenward
    200 Mb what? Wifi? The depends on the wifi client as well as the router.
