marshar's avatar
marshar
NETGEAR 21
Can someone please tell why I have "2" after my WiFi NETGEAR21? I am not able to access the internet as long as I use this router.   Thanks.
  • FURRYe38's avatar
    Sep 14, 2021
    To signify its a 2.4Ghz SSID signal. You can change that to anything. You don't have to use that SSID name. Try something different.
