Ksahiwala
Jul 23, 2021Aspirant
Netgear 6350 Timeout issue ?
I have Nighthawk R6350 Router with a Static(public IP) . We do have some issues in Power connectivty. Whenever there is a power cut my Router will not re-connect automatically. It will show on the Ne...
michaelkenward
Jul 24, 2021Guru - Experienced User
Why do you think the router is the problem? What about the modem?
Most routers sit behind a modem of some sort. Power cuts usually take out the whole network, including modem and router. When the power comes back on, it is important for these devices to come on in the correct order.
- Turn on modem. Wait 2 minutes for it to connect.
- Turn on router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
That seems to be the logic behind the advice that you get from the your ISP. Although there seems to be some sort of grammatical confusion in there. (or then?)
Ksahiwala wrote:
...they will advise me to switchoff the router for 10 mins and restart or then they will do a reset to my connection.
In the past I used a modem/router in modem only (bridge) mode. After a power cut, the modem bit took so long to connect that the router behind it gave up looking for an Internet connection and timed out.
I solved it by replacing the modem/router with a standalone modem.
Of course, an option that many people adopt is to use a UPS, Uninterruptible Power Supply.
- KsahiwalaJul 24, 2021Aspirant
I have a Smart Wifi router R6350 - Nighthawk.
I have a static IP (Public Ip)
Things are working, Suddenly Power Goes so is my internet connection.
Power comes up after 10 mins... Router is up, Shows Internet connection GOOD.
But I am not getting any internet services.
I wait for 30 mins, nothing happens.
I call Up the Broadband office , they tell me to switch off the router fr 10 mins.
after 10 mins I connect, mostly I get connected
I beleive they reset the connection from their console.
Now this does not happen if I am using a normal connection that is without STATIC IP.
With static IP , I was not facing any issue.
I know some setting needs to change somewhere and I think it has to do with Timeout.
kindly help
- antinodeJul 24, 2021Guru
> I have Nighthawk R6350 Router [...]
Firmware version? Connected to what? ISP?
> [...] Router is up, Shows Internet connection GOOD.
Does the ADVANCED > ADVANCED Home page show a valid Internet IP
Address and other parameters?> But I am not getting any internet services.
A vague description of what does _not_ happen is less useful than a
clear description of what _does_ happen. What, exactly, fails?ping 8.8.8.8
ping google.com> I beleive they reset the connection from their console.
I might know even less than you know about what they do. How much do
you actually _know_ about what they do?> Now this does not happen if I am using a normal connection that is
> without STATIC IP.What, exactly, did you change in the router settings when you got
this "STATIC IP [ADDRESS]?> With static IP [address], I was not facing any issue.
"Without"?
> I know some setting needs to change somewhere [...]
Then you know more than I do.
> [...] and I think it has to do with Timeout.
"Timeout" of _what_?
You don't seem to know enough about this stuff to make your analysis
of the problem worth anything. What _might_ be helpful would be if you
described accurately what you're doing, and what happens when you do it.
What you think it all means is much less interesting.When an ISP tells you that you have a "static" IP address, that may
or may not be literally true. The ISP might still want or allow you to
use DHCP to configure the WAN/Internet settings of your router. For
example, my service provides a "static" IP address, but the BASIC >
Internet settings on my router still include these:Internet IP Address
(o) Get Dynamically from ISPDomain Name Server (DNS) Address
(o) Get Automatically from ISP
In such a case, these IP parameters are not actually static, but the
ISP has reserved mine, and always supplies the same ones, using DHCP.
This might make more sense for the ISP, because _you_ might configure
your router using various bad/trouble-making parameters, and cause
problems for them.It's also possible that your ISP really does expect you to configure
your router with (true) static parameters.With my weak psychic powers, I can't see how _your_ router is
configured, or what your (unspecified) ISP wants you to do.
