iyadomry
Nov 21, 2021Aspirant
NetGear 7000v2 V1.0.0.76_1.0.1
Last update of NetGear d7000v2 broke the router. any one else see that?! update V1.0.0.76_1.0.1. really this is the first time I bought a router from Netgear and it will be the last score 0/10. ...
michaelkenward
Nov 22, 2021Guru - Experienced User
What did it break?
It is a DSL modem/router. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
DSL Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
