Bunny29
Jan 21, 2021Follower
Netgear AC1000 firmware upgrade assistant just spooling
Model R6080, Nighthawk firmware, OS. Have internet connection but the Firmware Upgrade Assistant is spooling and has been for the last hour and a half and hasn't moved ahead, it is on my iPad.
Any suggestions on how to get it moving or quitting out of it?
1 Reply
I would highly recommend against updating using the app or over wifi. I recommend any firmware changes be done over a wired connection to the router.
If its been going on for >10 minutes, something went wrong. Either the app failed, the router failed, or something just went wrong.
Is the router still working? You're able to use it?
