steven408's avatar
steven408
Follower
Dec 24, 2021
netgear ac1200 not connecting to comcast
i am not able to setup the netgear w phone
1 Reply
  • plemans's avatar
    AC1200 is a speed and not a model.
    And then your signature you put the A6150 which is a usb adapter which you wouldn't setup with your phone.
    So what device do you actually have?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with. You don't need the phone to install the routers.
