czesiodestrukto
Nov 25, 2020Aspirant
Netgear ac1750 / R6400v2 the power LED will flash red once
Hello, I got a netgear AC1750 / R6400v2 router from a friend that was only behind him. After trying to start, I noticed that there was no reaction except the power LED blinking red (only once, about a...
czesiodestrukto
Yes, I tried a button reset. No reaction
Nov 25, 2020Guru - Experienced User
Have you tried a 30/30/30 reset?
- czesiodestruktoNov 25, 2020AspirantAlso no reaction.
- czesiodestruktoNov 25, 2020AspirantEither it seemed to me or the power diode went green after turning it off and on (poc30 / 30/30). Turning on again red.
- plemansNov 25, 2020Guru - Experienced User
Last ditch? Try tftp and nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
