Jpitts1982
May 13, 2021Aspirant
Netgear ac1750 port forwarding not working
I am trying to setup an arma 3 server and no matter what I try the port forwarding will not open the ports. Here is how I have things setup. Arris sb8200 modem Modem shows security type is dpi+(do...
Jpitts1982
So I plugged the computer directly into the modem and tested ports again with the arma server running and still it says the port isnt open. Windows firewall is off and no other firewall software is used. Does this mean I might need to call comcast and see if it's something on their end?
antinode
May 13, 2021Guru
> Arris sb8200 modem
Simple modem. Should be harmless.
> Netgear ac1750 router
Not a model number. Look for "Model" on the product label.
> Firewall disabled on router
I don't know what that means to you. What does Netgear call what you
did?
> Static ip [address] set on pc (192.168.1.6)
How, exactly?
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Either one should fix the address of a
device, but some implications are different.
Generally, using DHCP address reservation (on the router) is simpler
to manage.
> Port test shows 2302 closed. [...]
What kind of "Port test"? At which address? From where? As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] I plugged the computer directly into the modem and tested ports
> again [...]
"tested ports" _how_, exactly?
> [...] with the arma server running and still it says the port isnt
> open. [...]
"it"?
> [...] Does this mean I might need to call comcast and see if it's
Unlikely. Your ISP can't stop your local activity, and it's unlikely
to stop your external activity.
For the usual problems with port forwarding, see:
- Jpitts1982May 13, 2021AspirantYea... think I'll wait for someone else to help that doesnt always have a condescending attitude when they try to help someone..
- michaelkenwardMay 14, 2021Guru - Experienced User
Jpitts1982 wrote:
Yea... think I'll wait for someone else to help that doesnt always have a condescending attitude when they try to help someone..While I understand you annoyance, the point is valid. We don't know what you are doing and where it goes wrong.
Ignore the snark and deal with the questions.
To begin with, your footer says C6300. That's a Netgear cable modem/router. Are you really using that alongside an Arris sb8200 modem? Not a good idea.
AC1750 is not a reliable guide to model number. Many devices come with an AC tag – I can find about a dozen AC1750s – but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
- Jpitts1982May 14, 2021Aspirant
ty for the reply. so its a netgear r6400v2 router.
ipv4 is set in windows as you see in the pics.
tested ports with portchecker.co and canyouseeme.org. both show port is closed.
here are some pictures of everything i have set.
well apparently my pics wont upload for some reason...
