Jpitts1982
May 13, 2021Aspirant
Netgear ac1750 port forwarding not working
I am trying to setup an arma 3 server and no matter what I try the port forwarding will not open the ports. Here is how I have things setup. Arris sb8200 modem Modem shows security type is dpi+(do...
Jpitts1982
Yea... think I'll wait for someone else to help that doesnt always have a condescending attitude when they try to help someone..
michaelkenward
May 14, 2021Guru - Experienced User
While I understand you annoyance, the point is valid. We don't know what you are doing and where it goes wrong.
Ignore the snark and deal with the questions.
To begin with, your footer says C6300. That's a Netgear cable modem/router. Are you really using that alongside an Arris sb8200 modem? Not a good idea.
AC1750 is not a reliable guide to model number. Many devices come with an AC tag – I can find about a dozen AC1750s – but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
- Jpitts1982May 14, 2021Aspirant
ty for the reply. so its a netgear r6400v2 router.
ipv4 is set in windows as you see in the pics.
tested ports with portchecker.co and canyouseeme.org. both show port is closed.
here are some pictures of everything i have set.
well apparently my pics wont upload for some reason...
- michaelkenwardMay 14, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
ah ok. i tried the attachment and it only let me add 1 file at a time. i will add them as attachments now.
