DeaconMGR
Dec 13, 2020Follower
NETGEAR ac1750 R6400V2 power solid amber, no internet connection
Netgear ac1750 R6400v2, one year old. I woke up one morning to my router acting werid. It was switching between power light solid amber, to power light solid amber and all lan ports, 1 thru 4, l...
Dec 13, 2020Guru - Experienced User
You might have a hardware failure. You can try recovering it via tftp or nmrpflash. Its worth a shot.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
